I'm in the middle of a 2wd pukey to 4x4 ax15 swap and I got the correct crossmember after quite some time, but the trans mount that I got seems to be either the wrong one or incomplete.
It has the studs to go into the crossmember, but only 2 holes in the top, exactly like this one: http://www.quadratec.com/products/52449_0560.htm
After a thorough search of just about everywhere I could think of, the only think I could find is that there is some sort of plate that mounts on top of that with an exhaust hanger implemented, seen below in a picture borrowed from superwade2
Now, the question is: where would I get one of those plates, or would it be better to get something like this: http://www.quadratec.com/products/52449_0561.htm that has the holes already in it.
It looks like the correct mount to me. There is 2 studs in the bottom of the transfer case that goes thru those 2 holes.
Got a pic of what you're talking about? Last AX-15 I pulled had 4 bolts that went through a plate and into the trans.
don't recall seeing 2 studs, in either of the AX15s i have. no pics to refresh my memory though.
