pamike Posted May 8, 2011 Share Posted May 8, 2011 this is not aimed tward comanche's but d44 axles in general. my brother has a 96 grand cherokee with the d44 rear axle. it has the aluminum center section. are the diff covers the same as all other d44's? i have a cover off a 78 cherokee with a d44 and he needs one because his is damaged and leaking. Link to comment Share on other sites More sharing options...
Motion Offroad Posted May 8, 2011 Share Posted May 8, 2011 Yes they are interchangeable. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 8, 2011 Share Posted May 8, 2011 this is not aimed tward comanche's but d44 axles in general. my brother has a 96 grand cherokee with the d44 rear axle. it has the aluminum center section. are the diff covers the same as all other d44's? i have a cover off a 78 cherokee with a d44 and he needs one because his is damaged and leaking. Alum center section = D44A axle. The 78 cover will not interchange with the D44A axle. Link to comment Share on other sites More sharing options...
pamike Posted May 8, 2011 Author Share Posted May 8, 2011 is there a place that sells new ones? or is a used one the only option? Link to comment Share on other sites More sharing options...
wvzj Posted May 11, 2011 Share Posted May 11, 2011 Blue Torch Fabrication sells new heavy duty ones for the 44A Link to comment Share on other sites More sharing options...
pamike Posted May 12, 2011 Author Share Posted May 12, 2011 gonna take the cheap way out and get one at the junk yard somtime. thanks for the help Link to comment Share on other sites More sharing options...
