CEThomas Posted December 22, 2006 Posted December 22, 2006 If I can not find a set of used drop brackets what other options are there to the front? Looks like we need about 5.25 to 6.5" of lift on the front, and dropping $350 is not in the cards right now. Charles
feerocknok Posted December 22, 2006 Posted December 22, 2006 Long arms would be another option. My fixed arms (the ones with the kink) barely clear at 5", so I wouldn't use them for anything bigger.
Oizarod115 Posted December 22, 2006 Posted December 22, 2006 Long arms would be another option. My fixed arms (the ones with the kink) barely clear at 5", so I wouldn't use them for anything bigger. thats probably MORE expensive...
feerocknok Posted December 23, 2006 Posted December 23, 2006 Long arms would be another option. My fixed arms (the ones with the kink) barely clear at 5", so I wouldn't use them for anything bigger. thats probably MORE expensive... Mostly trying to keep him away from the fixed arms.
Oizarod115 Posted December 23, 2006 Posted December 23, 2006 yeah, local 4x4 shops could probably build you some longarms for cheaper than the kits that are available... assuming of course you don't want y-arms and complete bellyskids and stuff. you could always go THIS route here... http://www.comancheclub.com/forums/viewtopic.php?t=2761&highlight=cheap+long+arms should be fairly inexpensive
Scott86mj Posted December 23, 2006 Posted December 23, 2006 this might help http://www.comancheclub.com/forums/viewtopic.php?t=2950
