btm24 Posted April 27, 2011 Share Posted April 27, 2011 Does any body know what the Torqure specs for the rear brake caliper bolts would be on a Ford 8.8? Thanks Brandon Link to comment Share on other sites More sharing options...
xjrev10 Posted April 28, 2011 Share Posted April 28, 2011 "Torque" Torque to SBM :yes: JK, I have always just tightened them well tight with a 3/8 ratchet. Nothing to specific :dunno: Link to comment Share on other sites More sharing options...
btm24 Posted April 28, 2011 Author Share Posted April 28, 2011 Ok well thanks any ways I just tighted it to 80" lbs. Brandon Link to comment Share on other sites More sharing options...
xjrev10 Posted April 28, 2011 Share Posted April 28, 2011 Ok well thanks any ways I just tighted it to 80" lbs. Brandon I was hoping you where going to ask what SBM meant :dunno: Link to comment Share on other sites More sharing options...
btm24 Posted April 28, 2011 Author Share Posted April 28, 2011 Ok well thanks any ways I just tighted it to 80" lbs. Brandon I was hoping you where going to ask what SBM meant :dunno: Standard base measurement? Brandon Link to comment Share on other sites More sharing options...
64 Cheyenne Posted April 28, 2011 Share Posted April 28, 2011 Is that like jistgitertightenough? Link to comment Share on other sites More sharing options...
xjrev10 Posted April 29, 2011 Share Posted April 29, 2011 SBM= ~~torque too "Slight Bowl Movement" Link to comment Share on other sites More sharing options...
btm24 Posted April 29, 2011 Author Share Posted April 29, 2011 SBM= ~~torque too "Slight Bowl Movement" cute ;) I don't think ill have to worry about the rear brakes for along time now :D Brandon Link to comment Share on other sites More sharing options...
comanche12 Posted April 29, 2011 Share Posted April 29, 2011 i never check up for tq spec on brakes wheni work on it for many years. caliper bracket bolt tend just tight it up with enough lever. but caliper bolt-don't just tight it well. just tight as snug. tight with 6" ratchet is good enough on caliper bolt. Link to comment Share on other sites More sharing options...
btm24 Posted April 29, 2011 Author Share Posted April 29, 2011 i never check up for tq spec on brakes wheni work on it for many years. caliper bracket bolt tend just tight it up with enough lever. but caliper bolt-don't just tight it well. just tight as snug. tight with 6" ratchet is good enough on caliper bolt. Good info thanks. My dad just said I should torqure them down hes picky. Brandon Link to comment Share on other sites More sharing options...
comanche12 Posted April 29, 2011 Share Posted April 29, 2011 ah gotcha well i understand. i can't blame him. I'm anal with tq spec for on engine. even like sparkplugs, etc. :oops: Link to comment Share on other sites More sharing options...
btm24 Posted April 29, 2011 Author Share Posted April 29, 2011 ah gotcha well i understand. i can't blame him. I'm anal with tq spec for on engine. even like sparkplugs, etc. :oops: Sparkplugs? thats a new one on me. I guess that if its from the factory it has a torque spec. And I just realized Ive been speelling torque wrong :oops: Brandon Link to comment Share on other sites More sharing options...
xjrev10 Posted April 30, 2011 Share Posted April 30, 2011 every bolt on the jeep probably had a engineer that figured out the optimum torque for each one. just something to complicate everything IMO. Link to comment Share on other sites More sharing options...
comanche12 Posted May 1, 2011 Share Posted May 1, 2011 yeah :agree: but really yes even sparkplugs hav tq spec. i rather tq it than strip the thread and have to replave the cylinder head :ack: :peek: or use helicoil than replace the cylinder head. :smart: Link to comment Share on other sites More sharing options...
xjrev10 Posted May 3, 2011 Share Posted May 3, 2011 I can agree with following torque specs for engine stuff. :thumbsup: Link to comment Share on other sites More sharing options...
comanche12 Posted May 3, 2011 Share Posted May 3, 2011 I can agree with following torque specs for engine stuff. :thumbsup: hah thank you now I'm not only anal person about it :) :banana: Link to comment Share on other sites More sharing options...
