windsheild decal
wast sure where to post this so here we go.
i got my window decals and was wondering how some of you guys had applied yous.
did the wet tek work or does the glue not work so well?
thanks in advance for any helpor tips?
this isnt my first decal install but I'm unsure of this one.
I've not installed a full windshield banner myself yet, but even for the smaller decals, I get the surface a little bit wet with a dish soap and water mix, which allows the decal to be positioned correctly before adhesion. When it's in the right place, use a credit card, hard rubber squeegee, or similar to force the water and air bubbles out and let it sit for a minute before pulling the clear film off. Anouther trick I've used it to leave the backing and everything in place, get it positioned correctly and use tape on either the top or bottom to keep it in place. Then it's a matter of removing the backing (carefully) and working your way with the squeegee, or item of choice, from the direction of the tape to the opposite edge.
Got the deacl on today. :clapping: it was a pita there was plenty of :mad: and I ruind one of the decals (that's why I got 2). So for anybody going to put there's on the wet tek works but wet a cloth and run it over the backing when ya get it smothed out on the windsheild cause the glue is prety strrong holding it to the papaer backing and the window cleaner I used for cleaning the glass (used soapy water to apply the decal) worked fairly well to help losin the glue on the backing.
Just thaught I wuld share my experiance :cheers:
Got pics? :brows:
Brandon
