btm24 Posted April 14, 2011 Posted April 14, 2011 When I was under my truck today I noticed that around the diff cover on the drivers side it looked like the cover seal was leaking. But I also noticed that the vent hose is ripped off. Could the vent be clogged and I just need to unclog it and replace the hose to stop the leak or do I need to re seal the cover? If it helps I can get a few pics latter. Thanks Brandon
SW86 Posted April 14, 2011 Posted April 14, 2011 this has nothing to do with your question but did you ever get around to lifting the front of your truck??
btm24 Posted April 14, 2011 Author Posted April 14, 2011 this has nothing to do with your question but did you ever get around to lifting the front of your truck?? No :thwak: And it's killing what ever was left of the front suspension and it makes backing up almost not possible. School is killing me for time and every time I have a free day the 4x4 shop is to busy to do any thing :( so I've just been doing what I can my self. Brandon
87Warrior Posted April 14, 2011 Posted April 14, 2011 I would repair the vent line and clean up the diff. If more oil shows up, pull the cover and try again. A pair of jack stands, a jack and set of good metric sockets and wrenchs is all you should need to lift the front. Grab a buddy and do it in the driveway.
SW86 Posted April 14, 2011 Posted April 14, 2011 sure the front is slightly harder then the rear to lift but really easy to do. i did mine by myself! of course i had my brother help muscle the axle around once or twice but it can be done. just pick a day and go. what you don't know youll figure out as you get there. I'm telling you.
