Tightned tilt column
My steering column was so loose I thought it was going to fall apart so this weekend I bit the bullet and dove in. I got a loaner steering wheel removing kit from Oreilly's auto parts and went to work. It was a tedious job but actually not that difficult. The hardest part was figuring out where the 2 or 3 parts that fell out during disassembly, went when reassembling.
I didn't have the little GM tool to remove the pivot pins so I made a slide hammer out of a 8-32 machine screw welded to a piece of 3/8" steel dowel with a nut welded at the other end. I used a heavy socket for the slide hammer.
Not really any new tech but thought I link a couple of articles that were very helpful.
http://www.bc4x4.com/tech/2009/jeep-steering/
http://www.epiccomputer.com/dale/jeepju ... /tilt.html
