Oizarod115 Posted December 20, 2006 Posted December 20, 2006 tera-flex disc brake conversion package for D44s... BOLT ON. http://northridge4x4.com/proddetail.php?prod=TF-DBK-J
Twisty Posted December 20, 2006 Posted December 20, 2006 i wish i knew about that before i purchased my new backing plates, and had the retaining plate pressed onto my axle. :mad:
pingpong Posted December 23, 2006 Posted December 23, 2006 look at the price450 :eek: Thats a complete axle at most J-yards and all the needed parts to do the swap
CWLONGSHOT Posted December 23, 2006 Posted December 23, 2006 Thats very true!!! Didnt the ZJ's have a D44 alum center with discs??? that should bolt right up...no??? I know the center section is different as far as D44's go but the axle ends should be same..... Merry Christmas Everyone, CW
feerocknok Posted December 23, 2006 Posted December 23, 2006 Thats very true!!! Didnt the ZJ's have a D44 alum center with discs??? that should bolt right up...no??? I know the center section is different as far as D44's go but the axle ends should be same..... Merry Christmas Everyone, CW But you'd have to grind off all the link brackets and the coil buckets, so that kinda sucks too.
pingpong Posted December 23, 2006 Posted December 23, 2006 Grinding stuff off is cheaper then that. My 14 bolt disc conversion is cheaper then that, and that is using all new stuff
CWLONGSHOT Posted December 24, 2006 Posted December 24, 2006 Thats very true!!! Didnt the ZJ's have a D44 alum center with discs??? that should bolt right up...no??? I know the center section is different as far as D44's go but the axle ends should be same..... Merry Christmas Everyone, CW But you'd have to grind off all the link brackets and the coil buckets, so that kinda sucks too. I am not sudggesting the whole axle...just the disc brakes!! The axle flanges from the alum D44al and a STD D44 should be identical!!!
