sinkrun Posted April 11, 2011 Share Posted April 11, 2011 I did my u Joints on my front axle on the 98XJ now I have a leaking inner seal. I can't find any how to on this I know its a big job but just how hard is it? Link to comment Share on other sites More sharing options...
Automan2164 Posted April 11, 2011 Share Posted April 11, 2011 It's one of those things thats not hard, but it takes a bit of time. You have to pull the carrier and drive them out. Usually I will use a bunch of extensions, and have used a broom handle in a pinch to get all the way down the tube to out it back in. Rob Link to comment Share on other sites More sharing options...
mvusse Posted April 11, 2011 Share Posted April 11, 2011 I made a 1" diameter 4' long oak dowel rod out of a scrap piece of wood I use. Works like a charm. Link to comment Share on other sites More sharing options...
Automan2164 Posted April 11, 2011 Share Posted April 11, 2011 Now that I have a chance to sit down at a keyboard, instead of a phone, here is my condensed version. Pull wheels/tires Pull brakes Pull Wheel bearings Pull axle shafts Pull diff cover Remove bearing caps Pry out the carrier Use whatever you can find to get down the tubes, and knock each seal into the middle Clean surfaces Put seals in by reversing the knockout procedure, except now you will be driving them in, So you will pound the passenger through the drivers side and in, and opposite for the drivers side. Install carrier and tighten caps to roughly 55 ft lbs Install diff cover Install axle shafts Install wheel bearings Install brakes Install wheels/tires Fill differential. That easy. :ack: Its really a walk in the park. Just kinda involved. Don't let it intimidate you. The part that gets most people is torquing the caps, but you can always rent a torque wrench. Rob :D Link to comment Share on other sites More sharing options...
sinkrun Posted April 11, 2011 Author Share Posted April 11, 2011 Thanks guys, I believe I will try it also maybe even a write up (it would be the first). I had this done before and it was almost $300.00 at the shop I just can't see spending that kinda money when I can do it myself. I have a torque wrench so I am good to go. Link to comment Share on other sites More sharing options...
alleydog Posted April 12, 2011 Share Posted April 12, 2011 I know it may need new seals, but maybe when you had the axles out, the lube just ran down the tube and now it's finally dripping out. then again it's good to do it now instead of when the diff is full of dirt and water Link to comment Share on other sites More sharing options...
