properly removing serpentine belt
there is 4 bolts you have to loosen before you loosen the tenchener bolt.
first one is above the P/S pulley then one under the pulley 13mm or 1/2''
then there is two more on the back of the P/S pump bracket loosen both with an open end wrench 13mm or 12mm
then loosen the tenchener bolt under the pulley parallel W/the belt
continue until the belt is loose. :wrench:
I replaced the alternator on mine not too long ago. It's easier to do it from the bottom. You won't have to remove the battery tray and I don't believe the alternator fits out the top any ways. The belt comes off just like mjMike said except you have to loosen another bolt on the end of the tensioner bolt. It should be pretty straight forward.
