Headlight Problem
Headlights only work when on bright? Is this a fuse or relay? Switch seems fine.
There is no fuse or relay. The switch has a circuit breaker built into it -- if the high beams work, the headlight switch is good. The problem is either in the dimmer switch, or in the wiring. (Unless, of course, both low beam filaments are burned out.)
