BoneStock
BoneStock's Achievements
  1. BoneStock
    Tailgate Net
    Anyone have a decent tailgate net for sale?
  2. Wrong bolt to begin with...used brand new OEM replacement bolt from Jeep and all is fine. Thank you for the replies. I really need a camper top for '91 long bed?
  3. I called mechanic. He replaced balancer but unable to bolt it back on properly. He tells me that the threads on the crankshaft are damaged. He purchased another bolt but same. The alignment is one groove off. I think what he means is that the bolt is not gripping deep inside and so the balancer can not be properly tightened all the way down.
  4. The belt is riding up on the balancer some now so I will replace balancer. My usual mechanic will not do this repair. What is going rate for this? Is it possible to do this without removing the bumper or too many other components? Any walk-thrus for this? Just pull balancer and replace? Size of bolt? Torque required? Any advice would be appreciated...
  5. Thank you for the replies. All suggestions check out and new belt is going on day 2 without any trouble. Thank you again!
  6. No, pulleys all look good. I thought of the balancer but it is on tight, no wobble...?
  7. I have a 1991 with belt problem. I purchased a year ago and previous owner warned of belt problem. Belt was squeaking and replaced several times due to squeaking to no avail. Belt dressing works for a while. I had no problems until last week, I just let it squeek, but gave a liberal soaking and squeek free for a few days then frayed. I replaced belt with best quality belt and it frayed again a few days later? All pulleys seem to be in proper alignment and are tight. I do not see a belt tensioner. Any advice or assistance would be appreciated.
  8. Unable to identify fuse for cigarette lighter for 1991 Comanche? Any diagrams available? I found a picture here for a different model comanche but mine is not the same.
  9. I need 1991 Comanche Rear Bumper in good to fair condition and cheap please? ...don't want anything too nice as hit in rear and will need to bend it some to get it on...need to be able to tow with it. :USAflag:
  10. Thank you, Gentlemen. Any advice or guide on dimmer replacement? Thank you again...
  11. Want drop in bedliner in Atlanta area. Prefer OEM...longbed. Don 770-445-4848
  12. Headlights only work when on bright? Is this a fuse or relay? Switch seems fine.
