Front Dana 44?
It will go in with some work. Thats what I have in the front of mine. If you want to keep the factory front suspention with coils and links you will need to fab up some mounts or buy some as I did. Aslong as it is not a wide track the width is perfect and you also have to make sure it is drivers side drop for the dif. Some of the waggys came with both. And just remember that the waggys are a 6 lug not a 5x4.5. Hope that hels you.
It is almost the same width as your D30. Depending on year it might be passenger or driver drop. If it is the correct side (driver), then you have to decide whether your going to adapt the axle to use the 4 link/panard bar coil spring suspension, or adapt your truck to use the axle's leaf spring suspension.
Wheel bolt pattern is different also.
