If I use the ZJ drag link do I still use the regular MJ TRE's for everything else? I would guess the 2 on the tie rod I would use Mj TRE's but what about the one at the pitman arm.
:agree: About everything else from the V8 ZJ steering/front suspension is beefier except the drag link. Same p/n for all. :cheers:
For some reason I was thinking it was the V8 ZJ draglink that was solid not the tie rod. Too much reading and my mind gets jumbled. So ZJ TRE with the ZJ tie rod and Mj TRE's for the drag link
Don't forget the V8 ZJ adjustment sleeve. The TRE attaches to the tie rod differently than the MJs.
For the drag link, get the MJ ends. I doubt they are referred to as a TREs though.
