wannabeMJ Posted February 21, 2011 Share Posted February 21, 2011 I was about to go for a test drive but when I started the truck today it was making a weird noise like I have a valve problem here is a video of it that tic tic tic the sound is going faster as I rev up the engine and also at low idle it kinda fade away for a couple seconds and then comes back any idea? Link to comment Share on other sites More sharing options...
JeffN Posted February 21, 2011 Share Posted February 21, 2011 is your oil pressure ok? If it is then it sounds like you have a lifter failing by not pumping up. Try and throw a can of seafoam engine treatment in the crankcase and see if it goes away. Link to comment Share on other sites More sharing options...
wannabeMJ Posted February 22, 2011 Author Share Posted February 22, 2011 just did the seafoam Ill let it run for about 10 min to see what it does Link to comment Share on other sites More sharing options...
wannabeMJ Posted February 22, 2011 Author Share Posted February 22, 2011 still there anymore ideas??? Link to comment Share on other sites More sharing options...
knever3 Posted February 22, 2011 Share Posted February 22, 2011 It sounds like it could be a lifter because it doesn't exactly follow rpms. You may have a collapsed one. How long did the motor sit? If it sat for a long time the oil might have run out of the lifter and it may take some time to get the oil back in it compared to removing them and letting them sit in a jar of oil and depressing them from time to time to get the air out. I don't know what seafoam is but I would drain the oil and put some cheap oil in it along with a bottle of Lucus Oil Stabilizer run it for a while until the noise suppresses and then change the oil with fresh good oil. It sounds like you have good oil pressure because it's only one lifter making noise. The only other scenario it could be is if a rocker arm was loose under the valve cover. This could be making noise against the pushrod or the valve tip. It wouldn't be a bad idea to pull the cover and see if they are all tight. You could also have a sticky valve but this would cause the engine to have a miss most likely and this does not sound like a miss to me. It's too loud to be a spark related issue also. I hope this helps and thank you for the video it's much more easy to diagnose these kind of problems. Good Luck!! Link to comment Share on other sites More sharing options...
wannabeMJ Posted February 22, 2011 Author Share Posted February 22, 2011 ok if I take the valve cover off I'm pretty sure I won't be able to save the gasket 1 what will I be looking for : loose parts, loose rockers 2 can I put RTV gasket maker instead of a real gasket ? by the way thanks for the answer Link to comment Share on other sites More sharing options...
knever3 Posted February 22, 2011 Share Posted February 22, 2011 Loose rocker nuts mainly. You could run the engine without the valve cover on and find out what lifter is sticking by placing a stick near the valve. The other end of the stick will be placed near your ear. DO NOT PUT THE STICK IN YOUR EAR! Kind of like a stethescope, by the way they sell automotive stethescopes at the auto stores cheap, a much safer way. Anyway back on topic if you take off the valve cover place some rags on the edges to soak up any oil so it doesn't run over your exhaust manifold since this could cause a fire if too hot. You may just be able to place your finger on the rocker stud nut and determine the one at fault. When the engine runs the tension will change if the valve is seated or closed. You can also take the time to remove the spark plugs and rotate the engine manually until each valve is seated, but that is way to much work in my opinion. On the cover gasket don't use RTV, it will leak and cause a huge mess. Get a felpro gasket to replace it when you have found the problem. The old one is probably cork and rock hard. Make sure the surface is very clean and all gasket material is removed before re-installing. Link to comment Share on other sites More sharing options...
Kenbob Posted February 22, 2011 Share Posted February 22, 2011 If you have any rubber vacuum hose and small copper tubing or wire that fits the inside diameter of the hose, it makes a swell scope for checking out all kinds of sounds. Make sure you put the metal end to the noise and the soft end to your ear and not the other way around. Actually, I have used a coat hanger for mechanical noises. Straighten it out. Keep the loop end resting on the ear lobe and the other end near the noise. Link to comment Share on other sites More sharing options...
