neverstuck Posted February 16, 2011 Share Posted February 16, 2011 88 Jeep Comanche 4.0L Exactly what the title says; i changed fuel pump/rail/regulator/injectors/ spark plugs and fixed all vac leaks so she purrs like a kitten to PASS inspection. I failed at idle, passed at high idle. Idle numbers Reading Standard Result- Fail :grrrr: HC ppm 227 220 CO% 5.07 1.20 High Idle numbers Reading Standard Result- Pass HC ppm 24 220 CO% .20 1.20 Any ideas on the dramatic differences? Turn the idle up? replace the cat? Replace 02 sensor? Thanks in advance Link to comment Share on other sites More sharing options...
cz777 Posted February 16, 2011 Share Posted February 16, 2011 sorry about your commie state codes! 02 is my vote... i believe in replacing them in three year or 60,000 miles intervenes like Bosch says ..... and yes another is how is your thermostat doing ?? if its stuck open cooling too much you will go rich too and talk of temps engine coolant temp sensor maybe going bad too ...grab a VOM and start testing some... Link to comment Share on other sites More sharing options...
Oizarod115 Posted February 16, 2011 Share Posted February 16, 2011 those numbers look like you were running rich or your cat is dead, but seein how you passed one and not the other i'd say it was running rich go back through your sensors Link to comment Share on other sites More sharing options...
neverstuck Posted February 16, 2011 Author Share Posted February 16, 2011 I need to do a coolant flush anyway so ill grab a thermostat and do that at the same time; ill grab an o2 sensor later this weekend when i have the money. Ive never changed it in the 6yrs ive owned it. (in the meantime ill work on the loosening the other one and getting it out). On second thought; i may be replacing the trac-bar with this weeks money since i finally aligned it right(last week) and now i have death wobble on occasion. I have until 3-11-11 to fix the emmisions but it sucks cause i just had the exhaust re-welded with a new muffler put on. Its goin to suck if i have to do a new cat, if i do I'm gonna run a stack through the bed this time. Then probably have them fail me for that. In the great communist state of New Jersey; who cares if my numbers are high at idle, i don't want to be idling; i want to be driving. Thanks for the help and Ill keep you posted :) Link to comment Share on other sites More sharing options...
neverstuck Posted February 16, 2011 Author Share Posted February 16, 2011 In the process of doing the thermostat. YES, it was stuck open. :wrench: Link to comment Share on other sites More sharing options...
cz777 Posted February 17, 2011 Share Posted February 17, 2011 BINGO i hope for you ....all is well soon! please let us know how its doing on your MJ ?,ok !thxs Link to comment Share on other sites More sharing options...
