Akula69 Posted January 31, 2011 Share Posted January 31, 2011 As the listing says, I am looking for the cable between the floor shifter and the automatic transmission. Thanks Link to comment Share on other sites More sharing options...
maddzz1 Posted February 1, 2011 Share Posted February 1, 2011 I switched from column shift to floor shift and used the same cable. Just rerouted thru a different hole in the fire wall. Link to comment Share on other sites More sharing options...
Akula69 Posted February 1, 2011 Author Share Posted February 1, 2011 I switched from column shift to floor shift and used the same cable. Just rerouted thru a different hole in the fire wall. Yeah, I thought about that but was kinda hoping someone would have one. Link to comment Share on other sites More sharing options...
neverstuck Posted February 27, 2011 Share Posted February 27, 2011 I switched from column shift to floor shift and used the same cable. Just rerouted thru a different hole in the fire wall. Id like to do that. Do you know if their are any writups on that? If not, What parts would i need? Link to comment Share on other sites More sharing options...
jimoshel Posted February 27, 2011 Share Posted February 27, 2011 I have one from a '97 ZJ. Will it work? Link to comment Share on other sites More sharing options...
Akula69 Posted February 27, 2011 Author Share Posted February 27, 2011 Ah - no, I don't believe so. But I should have closed this one out as Fiatslug87 was able to snag one for me. Thanks anyway. Link to comment Share on other sites More sharing options...
