casey Posted January 26, 2011 Posted January 26, 2011 GM 60 drw front complete with brakes hub to hub. New 4.88 gears - Trac-loc case with Powertrax No-Slip. Dodge D60 rear with new 4.88s - Detroit - bored spindles w/1.5" 35 spline shafts. Drum brakes with new parts. The rear would need the perches moved to bolt in. Will include new spacers to add wms. $2500 for the set. Just for grins I added up what I have in the set. Front axle purchase price $650 + gears $300(Yukon) -locker $460- new case $139 - install kit $125 and installation $200 = $1874 Rear axle purchase price $150 + gears $260 (Dana Spicer) - locker $585 - axle shafts $300 - machine work $150 - install kit and labor $325 = $1770 Work done by Chris Durham Motorsports http://www.reiderracing.com/product_inf ... 45&product s_id=2037 http://www.ringpinion.com/ProductDet...px?ProdID=8341 http://eastcoastgearsupply.com/i-132...ars-yukon.html http://eastcoastgearsupply.com/i-129...it-locker.html http://eastcoastgearsupply.com/i-126...it-master.html
shelbyluvv Posted January 26, 2011 Posted January 26, 2011 Isn't that front axle a passenger side drop?
casey Posted January 26, 2011 Author Posted January 26, 2011 Isn't that front axle a passenger side drop? It sure is. Wouldn't be the first I've seen in an MJ or XJ...
Incommando Posted January 27, 2011 Posted January 27, 2011 For not much cash you can buy a clocking ring to put a pass. drop d300 on the aw4 or this would be a great time to get a doubler, like northwest fab or box4rox, to turn your 231 into a range box doubled into a d300 or np205 to get pass drop. The cast iron gear-to-gear t-cases are so much stronger than the aluminium cased chain-driven t-cases. They are just heavy and deemed too noisy for the "refined" modern 4by's. :roll:
casey Posted January 27, 2011 Author Posted January 27, 2011 D300 will bolt right to a 23 spline MJ/XJ trans. 6 bolt round w/23 splines. I have D300 and both 203/205 to build a dblr with if you're interested... :chillin:
Archived
