Clifford header ?
Interesting. The Blackjack says the primary pipes are 1-1/2" (no problem there) and the collector is 2". But the down pipe for a standard 4.0L is a 2-1/2", and the catalytic converter is a 2-1/2" inlet and tube, that necks down to 2-1/4" between the cat and the muffler.
So how does the Blackjack mate up with the cat? Or do you have to use a completely custom exhaust system?
The Older XJ's Have a smaller Tubing so I think it will be fine but For the later models I see what your saying...
The Pipe Might Increase as it gets to the cat as The picture of the header shows that the Tube just bolts on like a stock system...
No, the older XJs do not have smaller tubing. I have an '87 MJ and an '88 XJ, both 4.0L. The down pipe is 2-1/2", the catalytic converter is 2-1/2", and the outlet of the cat necks down to 2-1/4" where it enters the muffler.
It was the early 4-cylinder models that had some funky pipe size variations.
It bolts right on. It has the pipe with the flange on it with the 4 bolts that connect to the factory system. In the photo below it's the shortest piece that is furthest back in the system.
