kbusch18 Posted January 21, 2011 Share Posted January 21, 2011 so i recently swapped out my 87 inline 6 automatic for a 94 inline 6 automatic me and my father kept most things original couple of sensor swaps my question is it has a rough idle cold and warm at some points when driving and come to a red light it will begin to act like its gonna putter and shut off but never does and if i am at a stop sign on a down hill slope and try to excel up a hill it will have no pick up and act like its gonna shut off is this something in the throttle body that needs to be cleaned Link to comment Share on other sites More sharing options...
Pete M Posted January 21, 2011 Share Posted January 21, 2011 what do you mean by "couple sensor swaps"? Link to comment Share on other sites More sharing options...
mvusse Posted January 21, 2011 Share Posted January 21, 2011 What Pete said. Also, are you sure the distributor is installed correctly and not off by a tooth (or more) on the drive gear. Keep the original 87 computer? What about the knock sensor? Link to comment Share on other sites More sharing options...
kbusch18 Posted January 24, 2011 Author Share Posted January 24, 2011 i switched out the sensors to make it run the basics for whatever a 94 needs to run i don't have a knock so the knock sensor isnt needed but it is in and the distributor is good as well the computer is original i was thinking something along the lines of the intake manifold if somthing that regulates air to fuel needed cleaned idk Link to comment Share on other sites More sharing options...
Pete M Posted January 24, 2011 Share Posted January 24, 2011 Did you retain the old 87 wire harness? Or did you swap in the new 94 wire harness? Or are you saying that you just swapped a block and transmission? Which intake did you use, old or new? Which distributor did you use, old or new? Which throttlebody? Which CPS? Link to comment Share on other sites More sharing options...
kbusch18 Posted January 24, 2011 Author Share Posted January 24, 2011 kept original wiring harness, i used the new distributor, i used old cps old intake, old throttle body i just swapped engine no tranny Link to comment Share on other sites More sharing options...
mvusse Posted January 24, 2011 Share Posted January 24, 2011 Sounds like a timing issue to me. I believe there is a difference between a Renix and a HO distributor. Since you're still using the Renix computer, you should be using the Renix distributor. Should also be using the knock sensor, although other people have successfully done without. I don't know what all sensors interchange between the two systems, but all the ones that don't should be swapped from the old engine onto the new. Also, do the ports on the old intake manifold line up with the ports on the new head? I though Chrysler moved the ports up some. Link to comment Share on other sites More sharing options...
kyleag89 Posted January 24, 2011 Share Posted January 24, 2011 You used the 87 intake and exhaust on the 94 head? Link to comment Share on other sites More sharing options...
Pete M Posted January 25, 2011 Share Posted January 25, 2011 which flywheel tone ring did you use? Link to comment Share on other sites More sharing options...
