Before I start building...
I want to get what I want to do down on paper so I don't get anything that I can't use. Okay I have a '86 with the 2.8 I did the 3.4 swap but haven't ran it yet so my question is...
1) I know you have to run an electric fuel pump for the 3.4L, but what do I have to do to the fuel tank? or can I just put the inline electric pump on and run it?
2) I have a 35 rear, I want to upgrade to 8.25 (newer 29 spline instead of 27) reason better then D35, I want to run 35s, and their common here/cheap. To do a SOA all I have to do is move spring perches in 1 inch on each side and weld them on the top of the axle. Then bolt up, right?
3)I want a 6.5 Lift any suggestions?
4) What will I need for drive shafts (keeping front axle a 30 for now, until I decide what I want to do with it)?
this should get me started
Thanks
