morty_d83 Posted January 15, 2011 Share Posted January 15, 2011 I got a 1986 Comanche long bed with a 2.8L V6. It has no power or torque to speak of. Being its a Chevy motor and all. Would I be able to swap it out for a 4.3L V6 or 305 V8? I have owned my Comanche for 10 years and figured it is time to fix it up. Or would it it be easy to change to a 4.0 I6? Link to comment Share on other sites More sharing options...
Pete M Posted January 15, 2011 Share Posted January 15, 2011 step one is to find out why your 2.8 is gutless. blown rings are bad, but a clogged fuel filter is easy. :thumbsup: easiest swap is the early 90s 3.4L v6 since it will bolt to your trans, exhaust, accessories, etc. and it's fairly straightforward to wire in the Camaro/Firebrd fuel injection if you go that way. after that is a 4.0 since if you're going to gut your entire truck, picking up a used XJ will give you a 95% bolt in job. after that is a 90* chevy engine (4.3, 305 etc). it won't work with anything you've got now, and you'll need lots of custom parts or a big checkbook. (your 2.8 is a 60* engine and shares nothing with the 90* blocks) Link to comment Share on other sites More sharing options...
artimus Posted January 15, 2011 Share Posted January 15, 2011 ill eventually do the 3.4. these 2.8s suck! Link to comment Share on other sites More sharing options...
morty_d83 Posted January 16, 2011 Author Share Posted January 16, 2011 http://www.crateenginedepot.com/HT-34-V6-Crate-Engine-S10-Truck-Repower-12363230-P25C2.aspx This is a 3.4L engine that I found online. I am curious if this is the engine you were talking about. Link to comment Share on other sites More sharing options...
Automan2164 Posted January 16, 2011 Share Posted January 16, 2011 Any old GM 3.4L will fit the bill. That one would, but I wouldn't spend that much money. Might as well spend that on a 4.0L conversion. Rob L. Link to comment Share on other sites More sharing options...
Car RamRod Posted January 16, 2011 Share Posted January 16, 2011 I was in the same boat as you a few years ago. I found an mj locally with a renix 4.0 and a five speed. The engine was just so I had to go for a reman, but everything else was a home run, it just took alot of time. The added power, driveabilitly, mileage and reliability are well worth it. Link to comment Share on other sites More sharing options...
