wanted 97+ 2door or 4 door pwr window/lock/mirror harness WA
i put 97+ doors on my mj and need the wiring that connects to the doors. i have the 4 door interior but would prefer the 2 door wiring then ill just get a 2 door door panel.
It is the same wiring. All you need is the switch. I thought it was different too.
I have a harness here out of a 2 door if you want to buy it. I paid $40 for it and that is what I would let it go for.
and you will need the 4 door door panels with the 2 door driver's side switch bezel...2 door panels are 9" longer than the mj ones...4 door ones are the same.
ok i have the 4 door panel and door wiring, just the mj didnt have pwr anything. so your sayin i can get the pwr stuff from any year mj/xj (wiring to fues block)?
