1986 transmission issue
ok i just purchased a 1986 comanche. it has a 2.5 with a 5spd 2wd. the issue I'm having is the truck doesnt want to go into gear. i just bled the hydraulic clutch so i know thats good. but if i hold the clutch petal in for a few seconds it will go into gear just fine.but what i wanna know is why it won't go into gear right away. my last comanche could go into gear right away. so i wanna know why won't it go into gear right away????? thx in advance
the reservoir is full. And I did remove the slave cylinder, compressed it, And hooked a tube from the bleeder to a jar of brake fluid. opened the bleeder then had my buddy push the clutch petal And I closed the bleeder. I did this a few times till there was no bubbles coming out. that's what alldata told me to do.
