cocy Posted December 23, 2010 Posted December 23, 2010 in the next few days I planing on changing my u-joints in my front axel. and changing the fluid in the diff. is there anything else I should look/change while I'm doing this? any input would be great.
jimoshel Posted December 24, 2010 Posted December 24, 2010 Check for play, sideways, on the pinion yoke and the output shaft from the transfer case..
Dirteatr717 Posted December 24, 2010 Posted December 24, 2010 While the front end is off the ground check all the steering/track bar sway bar... All thT stuff for loose nuts and bolts and play in anything :cheers: have fun with the u-joints!
cocy Posted December 27, 2010 Author Posted December 27, 2010 isnt there a seal where the axle shafts go into the houseing
Automan2164 Posted December 27, 2010 Posted December 27, 2010 Yes, and I would change it if you'll be that deep in. You'll have to pull the differential carrier, and knock them out... But I have never had a set that didn't leak out of the tubes after pulling axle shafts. I always replace them. You will need a torque wrench to put the bearing caps back on the carrier bearings. Rob L. :cheers:
Alex from China Posted December 27, 2010 Posted December 27, 2010 guys, how often you change U-joint?
Geonovast Posted December 27, 2010 Posted December 27, 2010 Every time it goes bad. Some last 10k. Some last 300k.
cocy Posted December 27, 2010 Author Posted December 27, 2010 ok this might sound dumb but I went down to the parts store and got the ujoints and told them I need the seals for the front axle shafts and they were saying there was an inner and outter and when they showed them to me there were just rubber. I figured it would be more like the metal/rubber seal. in short what seals do I need?
