Northup Posted December 21, 2010 Share Posted December 21, 2010 I was wondering if anyone has a photo or input on the OME 3" coils. I would like to run these on the front and get a set of 3" hell creek springs out back. My worry is jus the the front and back will not be a similar height even though they are both 3" lifts. Also on the front Should I just order the springs or will I have to worry about LCA or anything else. Thanks for any input. Link to comment Share on other sites More sharing options...
Motion Offroad Posted December 21, 2010 Share Posted December 21, 2010 OME does not make a XJ/MJ 3" coil spring. They only make a 1.5-2" (930) coil. You can however use the OME ZJ 1" V8 coil (934) and get aprox 2.5-3" of lift on the XJ/MJ's. Just be aware that the 934 coil has a higher spring rate (180lbs) and will ride a bit stiffer (harsher) than what many think OME coils should ride. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 22, 2010 Share Posted December 22, 2010 I used the OME 930 coils on my truck w. an extra spring pad and got a full 3"" lift. The only thing I needed to do was get the 92+ XJ longer sway bar end links, and add an adjustable track bar as it shifted the axle off-center about 1/2". These springs really ride and handle well. Link to comment Share on other sites More sharing options...
mnkyboy Posted December 22, 2010 Share Posted December 22, 2010 Here is my XJ with OME934 coils,originally I had them in the MJ with 2" pucks for a 5" lift . Link to comment Share on other sites More sharing options...
Northup Posted December 22, 2010 Author Share Posted December 22, 2010 Oh dang I really thought OME made a 3" coil. Must have misread it somewhere. Ya i really have heard great things about their coils, and I ran their 2.5" leafs on my old YJ. I'm looking for a nice ride cause the comanche rarely sees much besides payment and unpaved fishing roads. Any suggestions would be nice. I may go look at Rubicon express next Link to comment Share on other sites More sharing options...
mnkyboy Posted December 22, 2010 Share Posted December 22, 2010 My xj rides pretty good with the OME934's Link to comment Share on other sites More sharing options...
