Testing 4.0L IAC Valves
Does anyone have any details on how to test an IAC valve? I've looked in my '89 FSM and can find nothing.
I've got a bunch of them sitting in a box and I want to know which ones are good/bad for obvious reasons, I've also acquired a '94 ZJ with the 4.0L and would like to test the one it has as well, however it is slightly different than all of the Renix MJ ones I have, 4 pin plug looks to be the same though... Plan on cleaning the TB this weekend to see if that helps clean up the rough idle, probably needs other tune up parts replaced too.
I've got a 12V battery in the shop to use to test it, I just need to know which pins to put voltage to...
