Incommando Posted December 9, 2010 Share Posted December 9, 2010 Found a complete 3.55 front end from a '96 to get 297 joints. do the hoses interchange? Link to comment Share on other sites More sharing options...
mnkyboy Posted December 9, 2010 Share Posted December 9, 2010 Should be bolted on,so you shouldn't need a torch. It was meant to go under the bumper so it hangs down a lot. I cut mine and moved it up several inches so it doesn't hang up on stuff but I also don't have a factory bumper. Link to comment Share on other sites More sharing options...
Incommando Posted December 9, 2010 Author Share Posted December 9, 2010 Should be bolted on,so you shouldn't need a torch. It was meant to go under the bumper so it hangs down a lot. I cut mine and moved it up several inches so it doesn't hang up on stuff but I also don't have a factory bumper. Do you have details on how you tucked your up/modded it? Link to comment Share on other sites More sharing options...
mnkyboy Posted December 9, 2010 Share Posted December 9, 2010 Should be bolted on,so you shouldn't need a torch. It was meant to go under the bumper so it hangs down a lot. I cut mine and moved it up several inches so it doesn't hang up on stuff but I also don't have a factory bumper. Do you have details on how you tucked your up/modded it? I pretty much just cut the tube from the brackets and moved it up then welded it back together. As for the brake calipers I have a 94 axle in my MJ,my stock hoses wouldn't fit my 94 calipers so I had to use the 94 hoses till I got my extended hoses. Link to comment Share on other sites More sharing options...
