pug Posted November 29, 2010 Share Posted November 29, 2010 Put in rebuilt engine added antifreeze oil etc. Took out for test drive everything was good when i got back checked oil it was a quart low. I this normal no oil leaks made sure dipstick was all the way down also. thanks Link to comment Share on other sites More sharing options...
Automan2164 Posted November 29, 2010 Share Posted November 29, 2010 It is normal for a new/rebuilt engine to use some oil until the rings set. You check is right after you got back? Did you give the oil time to get to the pan? Rob L. :dunno: Link to comment Share on other sites More sharing options...
pug Posted November 29, 2010 Author Share Posted November 29, 2010 Yes checked when i got back only 5 miles. Then checked about 1/2 hour later. Link to comment Share on other sites More sharing options...
jpdocdave Posted November 29, 2010 Share Posted November 29, 2010 A completely dry engine will take a little more oil than you're used to adding during an oil change also. If you put 6 quarts in the initial fill, and checked it half hour after driving, I'd just top it up, and check it again after next drive. Link to comment Share on other sites More sharing options...
pug Posted November 29, 2010 Author Share Posted November 29, 2010 6 quarts in a 2.5 with 10 oz of brake in additive. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted November 29, 2010 Share Posted November 29, 2010 Some of the factory manuals will give you dry fill and wet fill amounts, about 2 quarts more than normal 4 quarts for a 2.5 sounds about right. Just add to top off, and re check often to see whats going on. Link to comment Share on other sites More sharing options...
pug Posted November 29, 2010 Author Share Posted November 29, 2010 Will do thanks Link to comment Share on other sites More sharing options...
