89JeepMJ Posted November 25, 2010 Share Posted November 25, 2010 On a 89 MJ 4WD what are the two circle relays attached to the fuse box under the column for :???: . any comments would help thanks guys. Link to comment Share on other sites More sharing options...
lostissues Posted November 25, 2010 Share Posted November 25, 2010 pretty sure they are flasher relays. Link to comment Share on other sites More sharing options...
mule13 Posted November 25, 2010 Share Posted November 25, 2010 yea ones a 4way flasher the other is the turn signal flasher Link to comment Share on other sites More sharing options...
jimoshel Posted November 25, 2010 Share Posted November 25, 2010 Upper left hand is turn signal. Lower right hand is hazard. Link to comment Share on other sites More sharing options...
89JeepMJ Posted November 25, 2010 Author Share Posted November 25, 2010 Could that cause my right blinker to be dimmer then my left. if my relay is going bad? Link to comment Share on other sites More sharing options...
jimoshel Posted November 25, 2010 Share Posted November 25, 2010 No. That would be caused by a bad connection, usually a corroded ground at the affected socket. Link to comment Share on other sites More sharing options...
89JeepMJ Posted November 26, 2010 Author Share Posted November 26, 2010 Alright thanks that narrows my search a lot :thumbsup: Link to comment Share on other sites More sharing options...
