btm24 Posted November 22, 2010 Posted November 22, 2010 To day i went to a JY and got my self a stock clock that gos next to the radio. i got the entire clock with the the "plug" on the back. dose any body know if what i plug this into is behind the dash already? or do i have to make somthing to make this work. thanks Brandon
fbtased2002 Posted November 22, 2010 Posted November 22, 2010 Don posted this link just last week about the clocks. The wiring is back there.. mine was stuck behind the gauge cluster though. http://gojeep.willyshotrod.com/HowtoDashClock.htm
btm24 Posted November 22, 2010 Author Posted November 22, 2010 thank you so very much idk how I didnt see that Brandon
dasbulliwagen Posted November 23, 2010 Posted November 23, 2010 My 87 had the clock wiring already there, but the fuse had never been used and didnt make good connection, so pull the clock fuse and clean it to make sure that your new clock will work properly. And the wiring between 86 and 87 up clocks are different , so make sure to get the right year for your truck. I found this out the hard way, and now my truck has the connectors for both!
