ComancheKid45 Posted November 10, 2010 Share Posted November 10, 2010 Alright guys, Ill start out by saying Manual Transmissions are a new thing to me, all my previous Jeeps are Autos. Anyway my 90 Eliminator equipt with an AX15 needs the clutch line replaced. The rubber has deteriorated away and was seeping fluid last night when i peeked. I can get 1 from work (advance) but if theres another good option out there let me know. Is replacing this line a hard job, it looks like a threaded fitting on 1 end but i couldent see excatly where the other end was. Also is there a howto on bleeding the clutch after the line is swapped? I figured Id get this done before I'm out 1 day and it decides to go "pop" Thanks for any help! :cheers: Link to comment Share on other sites More sharing options...
jimmy21669 Posted November 10, 2010 Share Posted November 10, 2010 That is an internal slave correct? If so, the line should be connected by the slave and master cylinders. Once replaced, gravity bleed the clutch first (open the bleeder screw on the end of the line that comes out of the bell housing). Then you bleed it much like brakes. Have someone pump and hold the clutch while you crack open the bleeder screw and repeat until all the air is removed. Keep an eye on the master fluid level since it is not a very large reservoir. This is a VERY easy process. Sometimes with the internal slaves, you will have to repeat bleeding 2 or 3 times. If it is external, let me know, their is a trick to it I can share. Link to comment Share on other sites More sharing options...
ComancheKid45 Posted November 10, 2010 Author Share Posted November 10, 2010 Yep its an internal. I looked it over again this evening and seems pretty straight forward. Thanks! :thumbsup: Link to comment Share on other sites More sharing options...
jimmy21669 Posted November 11, 2010 Share Posted November 11, 2010 No problem. Link to comment Share on other sites More sharing options...
Comanche County Posted November 11, 2010 Share Posted November 11, 2010 gravity bleed the clutch first (open the bleeder screw on the end of the line that comes out of the bell housing). Yep, it should gravity bleed just like he says then bleed it like brakes if necessary. Link to comment Share on other sites More sharing options...
