Rough Idle ! ? ! Tune up time ? ? ? . . .
Ok normally i fire the ol'2.5er up let it run through the High idle cycle then drive worked great all last winter and throught till about a week ago . . .
It now has some hesitation while acceleration like a half miss type sensation, Once heated up hot goes away runs great but idles a bit rough and has progressively gotten rougher . . .
Sensor's have all been replaced, Vacuum leaks have been fixed, and i even fixed that exhaust leak so i'm guessing its timing chain ? or tune up time ? . . .
Mike
Once it reaches operating temp for a few miles it'll chitty chatter while idling . . . Sound's like a loose timing chain rattle against some thing or Rust on the Idler pulley but that would wear off and be here cold as well as hot . . .
Maybe the old 2.5er is wearing out :hmm: there is 195K miles on it after all :yes:
Unless its just supposed to chatter, I know GM's 2.5 rattled and CryCo's 2.5 chattered, just this sounds way different then the racket those 2 engines make . . . But then again this a different 2.5 . . .
Mike
I guess different 2.5 means different Rattle/Chatter Seems like all the Big 4's from the home land make noise of some kind even them Ford 2.3s Clattered once they got miles on them.
I would still like to know whats up with that rough Idle and if the Chatter/rattle/Clatter is part of it ? been noisy since i bought it, the rough idle is a new thing . . .
Mike
sorry dude, i really don't know what to tell you.
I'm surprised people weren't all over this post????
good luck anyways :cheers:
I'm over i simply went else where . . . I have gotten more help in half the time so i'm done here
:waving:
Mike
