MancheKid86 Posted October 31, 2010 Posted October 31, 2010 like what the title says, i think its the u-joint for the front left wheel? how easy to fix?
freakjeep93 Posted October 31, 2010 Posted October 31, 2010 shouldnt be too bad. ive never done a u joint on a truck but its pretty easy on a atv.
Garvin Posted October 31, 2010 Posted October 31, 2010 The u-joints aren't that hard to replace. The hardest part in the whole disassembly is removing the hub. Including the lug nuts, there are about 11 bolts (5 lug nuts, 2 caliper bolts, 1 axle nut, 3 hub assembly bolts). Replacing the u-joint in the axle, itself, is easy also. You can either use the two sockets and hammer trick or can get the actual tool. I personally use the two sockets and hammer.
Dirteatr717 Posted November 1, 2010 Posted November 1, 2010 Just lift up the front end with a jack and wiggle the u-joint to see if they clank, easy way to tell :)
