The u-joints aren't that hard to replace. The hardest part in the whole disassembly is removing the hub. Including the lug nuts, there are about 11 bolts (5 lug nuts, 2 caliper bolts, 1 axle nut, 3 hub assembly bolts).
Replacing the u-joint in the axle, itself, is easy also. You can either use the two sockets and hammer trick or can get the actual tool. I personally use the two sockets and hammer.
