project Old Rusty (new panel welded in)
  • Replies 61
I have to take my bed off for the body shop, just don't have enough time with my job...
Was it hard to take the bed off.
My bed is in worse condition than yours. :wall:
Looks like your doing a really good job keep it up and keep us up to date! :cheers:
well thank you :yes:
its nice to have some feed back on my work :wrench:
it wasnt too hard,
i disconected my roll bar
removed the 8 bolts to the bed
then disconected the ebrake,
wiring, and dropped the gas tank.
i used a 3 foot breaker bar to remove the bolts,
make sure you soak them into penetrating solvents.
and tighten then un-tighten over and over as you are removing the bolts,
this will clear any crud that is caked on the bolts.
i broke 4 or 5 of the bed bolts.
so i have to pound out the old bolts n coils.
i used this gator grip socket to get stripped bolts out,
worked like a charm
http://s.kmart.com/is/image/Sears/9990000003389511
will be going out of town for about of week,
so i will update when i get back
finished my license prohibition,
no more stupid drivin for me, thats how i lost my first MJ Mary Jane
***EDIT***
PS.
i get my sister to help me lift the truck bed :dunno:
  • 3 weeks later...
time for an update?
i think so :clapping:
been a while (been workin my @$$ off during the day, and partying during the night lmao)
also got my lazy @$$ accepted into college and start in sept,
going to be an aircraft maintenance engineer mechanic specializing in helicopters :brows:
got some time today to do this
more cutting :yes:
all ground down
my neighbor doing his thing (metal bump'in whisperer)
tracing out card board cut out for sheet of metal (gave 1/3 inch of metal for overlap for everything except for bottom which is flush)
peice of metal after the "nibbler" got ahold of it
all bent up
drilling holes for spot welds
Bart doin his thing
all ground down
primed
before and after
finally found the wiring diagram in the Renix FSM.
and wired in my high beam switch manually,
turns out i got the right part sent to me, just the previous owner took a switch out of a 91+ cherokee.
will probably weld more metal in tomorrow.
:thumbsup:
  • 5 months later...
  • 3 months later...
  • 2 years later...
looks like this truck is coming back to me,
plans are
SOA rear
short arm 4.5" lift front
35" tires
standard swap
and flat deck
total cost of build should be under $200
$20 for the truck after i sell a set of 33's
and i have all the axles tcase tranny ect to toss in at hand
so only cost being money to do a flat deck
goal is to be a ready to wheel Daily Driver
buy it this weekend, pics to come shortly when build commences
