JeepcoMJ Posted October 26, 2010 Posted October 26, 2010 alright. I'm converting my '87 comanche with a '95 H.O. conversion to a '99 cherokee. it's a 4.0/auto/np231 obviously I'll have to swap the... throttle body sensors intake sensors distributor coil alternator temp sensor (and block off rear sensor hole) wiring harness (which will require a few different holes cut in the firewall, and some blocked off) heater box the neutral safety switch will be swapped because of 2 reasons...different connector, and mine is bypassed as it is bad. my question is this... I have a '95 AW4 in the truck right now. there is nothing wrong with it. I don't want to pull it out, because it has fresh fluid in it. there's no reason to unless rumors are true and there is, in fact, an added sensor on the '97+ aw4. I also don't want to swap the flexplate. for the same reasons. I THINK that the timing windows are the same (based off the fact that geonovast's brother has a '91 flywheel in his '99 xj). my plan is to take a junk engine harness I have, cut the '95 aw4 connector out of it, and cut the connector off of a junk '97 aw4 I have here, splice them together to make a jumper, and put it in so I don't have any permanent hack job wiring. any thoughts?
Pete M Posted October 28, 2010 Posted October 28, 2010 my thought... wiring makes my head explode. :headpop:
JeepcoMJ Posted October 28, 2010 Author Posted October 28, 2010 eh. easy for me. i like wiring. figured it out, though. I have to use a '97 ECU and TCU to use the '95 trans, since '97 didn't have a spare sensor yet... strangely convenient that I have those parts already... :dunno:
Pete M Posted October 28, 2010 Posted October 28, 2010 yeah, "convenient". and Drs think it's convenient that the hospital has bandaids. :D
