rics87 Posted October 26, 2010 Share Posted October 26, 2010 I hope this post will not go on too long, here goes.1987 4.0 5-speed 185,000mi on clock still orig engine. Broke down 2mos. ago found the dist gear broken,replaced re set dist. by placing at TDC moved oil pump to 11:00 pos. as per how to reset timing once engine turned.Popped in and pointed to #1. Start engine idles,But stumbles and spits thru pipe @2000rpm.Replaced evry known sensor on truck! evn new injectors.No plugged cat. Still no resolution.At my wits end,but not giving up. Link to comment Share on other sites More sharing options...
Geonovast Posted October 26, 2010 Share Posted October 26, 2010 With #1 at TDC, the rotor should be pointing just past #1 post, not directly at it. Link to comment Share on other sites More sharing options...
rics87 Posted October 26, 2010 Author Share Posted October 26, 2010 okay, so the rotor should be just past #1? do you mean its' whole witdh? i'll try it thanks Link to comment Share on other sites More sharing options...
mvusse Posted October 26, 2010 Share Posted October 26, 2010 Yup, sounds like your timing is off. By more than one tooth too. Link to comment Share on other sites More sharing options...
Eagle Posted October 26, 2010 Share Posted October 26, 2010 You could also be 180 degrees out of time. Remember, the crankshaft goes around twice for every one revolution of the distributor, with each cylinder coming up twice -- once for compression (which is when it fires) and again for exhaust. Let's just say that I know how easy it is to forget that, and set the distributor so it's firing on the exhaust stroke. Link to comment Share on other sites More sharing options...
Geonovast Posted October 26, 2010 Share Posted October 26, 2010 Eagle said: You could also be 180 degrees out of time. Remember, the crankshaft goes around twice for every one revolution of the distributor, with each cylinder coming up twice -- once for compression (which is when it fires) and again for exhaust. Let's just say that I know how easy it is to forget that, and set the distributor so it's firing on the exhaust stroke. I don't think that's it, since he says it runs. But his dizzy is definitely off. Link to comment Share on other sites More sharing options...
airspeed Posted October 26, 2010 Share Posted October 26, 2010 I had a similar situation with my 2.5 when I was putting it together. The distributor post is a 4:00 and the rotor needs to be set at 6:00. I kept looking at that and thinking this can’t be right, I had two different manuals and they both said the same thing. You stop and think the engine actually fires ~ 10-15 BTDC, that rotor is probably in the right place. Link to comment Share on other sites More sharing options...
