Rustybucket Posted October 19, 2010 Share Posted October 19, 2010 1987 4.0 aw4 2wd well my first problem is that i was trying to replace the tranny oil cooler lines, and ended up breaking off the tip of the cooler line into the female piece on the tranny(aw4) can i remove the nut(female piece) from the tranny to remove the tip of the cooler line i broke? pictures: Image Not Found and Image Not Found second leak i have is from my rear diff, first thing i did was the cover gasket and new fluid, didnt change anything.... so now ive noticed that its coming from the area that the driveshaft is connected to, my question is, is that a seal that i can replace? here's a picture: Image Not Found Link to comment Share on other sites More sharing options...
jimoshel Posted October 19, 2010 Share Posted October 19, 2010 Yes, to both questions. Be careful with the tranny fitting. You don't need another broken fitting. If it seems tight, then clean around the area good. Last thing you need is dirt in the trans. Soak with penetrating oil. let set. I've never had one that tight but then ya never know. Drop the rear driveshaft. There's a big nut holding the pinion input shaft. Getting that nut off is the hardest part. Link to comment Share on other sites More sharing options...
Geonovast Posted October 19, 2010 Share Posted October 19, 2010 Make sure the truck cannot move before you loosen and tighten that nut. Link to comment Share on other sites More sharing options...
Automan2164 Posted October 19, 2010 Share Posted October 19, 2010 For the pinion nut and seal at the axle: Chock wheels to prevent movement. Unbolt the straps on the u-joint (4-8MM bolts) Use a prybar to "pop" out the u-joint from the yoke. Once thats free, just pull the driveshaft out of the trans (it will slide right off, put a pan under to catch any fluid) Count the threads showing on the pinion (What the nut is screwed on to) Use a socket, paired with an impact preferrably, and zip that nut off. Hit the back of the yoke with a mallet of lightly with a hammer towards the front of the jeep to pull the yoke off. Once the yoke is off, use a flat screwdriver to get under the seal around the pinion and pry out. Clean all surfaces Reinstall a new seal with gentle taps around the edge to seat it in Slide the yoke back down onto the pinion Tighten the nut down to the number of threads as it had when you took it off (! Important to not overtighten or leave too loose, axle damage could result !) Re-install shaft. Rob L. :D Link to comment Share on other sites More sharing options...
Rustybucket Posted October 20, 2010 Author Share Posted October 20, 2010 So that diff seal, will replacing it help stop this mad vibration I'm experiencing while driving on the highway at 65+mph? And thanks for the responses/help Link to comment Share on other sites More sharing options...
Geonovast Posted October 20, 2010 Share Posted October 20, 2010 No, all the seal does is stop fluid from coming out of the diff. If you have a mad vibration from your driveshaft, either your driveshaft is out of balance, one or both of your U-joints are bad, your pinion angles aren't right, or your pinion bearing is bad too. Were there any metal shavings in the fluid when you changed it? Link to comment Share on other sites More sharing options...
Rustybucket Posted October 20, 2010 Author Share Posted October 20, 2010 No metal shavings Link to comment Share on other sites More sharing options...
Geonovast Posted October 20, 2010 Share Posted October 20, 2010 Probably wouldn't be a bad idea to change your U-joints to see if that's the problem. Link to comment Share on other sites More sharing options...
Rustybucket Posted October 21, 2010 Author Share Posted October 21, 2010 well i got the AN fitting off Image Not Found now my only problem is that i can't get the tip of the oil cooler tube out. so anyone know if i can pick one of these up from the local auto store, or will fate take me to the stealership Link to comment Share on other sites More sharing options...
Geonovast Posted October 21, 2010 Share Posted October 21, 2010 AX-15 swap? :brows: Link to comment Share on other sites More sharing options...
Garvin Posted October 21, 2010 Share Posted October 21, 2010 I'm not sure what you have around you, but the auto parts places around me do have a bunch in stock. It would just be a matter of taking the end to the store and having them match it up. Link to comment Share on other sites More sharing options...
Rustybucket Posted October 22, 2010 Author Share Posted October 22, 2010 Oriely autoparts for the win Link to comment Share on other sites More sharing options...
