knever3 Posted October 18, 2010 Share Posted October 18, 2010 Ok this is going to take some thought all of you. First off the parts I do have are a '93 231J auto transfer case and a complete ax-15/231J with clutch flywheel and bell housing. The only parts I would need to complete the 4wd swap is a new hard line for the internal slave to the clutch master cylinder. I already have the new front non disco axle in front installed and driveshafts set aside. So I must say I would like to go Automatic because I don't like having a clutch in the truck. I would like an Automatic with cruise control. I would like to have a donor truck with all the necessary parts, floor shift auto with cruise. I can pick up a donor cherokee but the miles would be very high likely from the '88-'90 range. Or I can pick up a newer one and pick between my transfer case and the donor. The only problems I guess would be the electric speedo and throttle body from the non renix with the cruise. I'm between a real rock and a hard place with this because the parts I have would be just a little labor to install. What are your opinions and advice?? My parts plus the aformentioned '93 231J. Link to comment Share on other sites More sharing options...
Geonovast Posted October 18, 2010 Share Posted October 18, 2010 Why do you not want the 5 speed? Speedo is not a problem. Unscrew the electric sender on the trans. The housing that holds the speedo gear is the same for the electric and the cable. Once you remove the electric sender, your cable will screw right on. Link to comment Share on other sites More sharing options...
knever3 Posted October 18, 2010 Author Share Posted October 18, 2010 That's good news for the electric speedo!! I want to be able to put it in drive and go not having to down shift for stop lights and such. My real hope is someone would have a donor I could swap them for my complete parts. :D Link to comment Share on other sites More sharing options...
Geonovast Posted October 19, 2010 Share Posted October 19, 2010 So you don't want the 5 speed because you don't like shifting? Ok. I was just wondering if you wanted the auto solely for the cruise.. because sticks can have cruise. (you don't have to downshift for lights) Link to comment Share on other sites More sharing options...
knever3 Posted October 20, 2010 Author Share Posted October 20, 2010 I don't want the automatic just for cruise and yes I know you don't have to downshift for stop lights, it was just for example. If I wanted a stick I would buy a fun sports car. I want this truck to be easy to drive and I haven't taught my girlfriend to drive a stick yet. Does anyone want to trade the setup I have for a donor Automatic XJ?? I know it's a LOT more work to install the auto but in the end I don't want any excuses why I don't drive it much. Link to comment Share on other sites More sharing options...
Geonovast Posted October 20, 2010 Share Posted October 20, 2010 Feel like driving to Missouri to get one? :brows: Link to comment Share on other sites More sharing options...
knever3 Posted October 20, 2010 Author Share Posted October 20, 2010 Feel like driving to Missouri to get one? :brows: Only if it's the '99 XJ you mention in your list!! Link to comment Share on other sites More sharing options...
