wannabeMJ Posted October 15, 2010 Share Posted October 15, 2010 Am I gonna damage the prop valve if I heat it to remove the old lines from it? Link to comment Share on other sites More sharing options...
wannabeMJ Posted October 15, 2010 Author Share Posted October 15, 2010 can I do it to he master cylinder to? Link to comment Share on other sites More sharing options...
jimoshel Posted October 16, 2010 Share Posted October 16, 2010 If your not going to use it again, then go ahead. Otherwise suggest you use a wire brush and get as much rust and crap off the fitting as possible. Then spray with rust penetrating solution. Let set overnight, or longer if necessary. Link to comment Share on other sites More sharing options...
Eagle Posted October 16, 2010 Share Posted October 16, 2010 What do you mean by "proportioning valve"? If you are referring to that junction block next to the master cylinder, that is not a prportioning valve on the MJ. However, it does have rubber o-rings inside, so I would recommend against using heat. The block itself is aluminum, so it won't take a lot of heat to do serious damage. Link to comment Share on other sites More sharing options...
wannabeMJ Posted October 16, 2010 Author Share Posted October 16, 2010 What do you mean by "proportioning valve"? If you are referring to that junction block next to the master cylinder, that is not a prportioning valve on the MJ. However, it does have rubber o-rings inside, so I would recommend against using heat. The block itself is aluminum, so it woon't take a lot of heat to do serious damage. TY thats what I wanted to know Link to comment Share on other sites More sharing options...
