87Chief Posted October 15, 2010 Share Posted October 15, 2010 Hey guys, when I drove my mj, it wanted to veer to the right all the time. I'm not sure what it would be... Also, my steering wheel column is loose. Any fixes on that? I know there is a website on it but can't find it. Thanks Link to comment Share on other sites More sharing options...
kar120c Posted October 15, 2010 Share Posted October 15, 2010 Could be a number of things or combination thereof. Alignment out of wack, loose suspension, sticky brake caliper, air in brake lines, etc..Is your truck stock or lifted? Helps with diagnosing problems. Link to comment Share on other sites More sharing options...
deziped Posted October 15, 2010 Share Posted October 15, 2010 To fix that loose steering wheel check this: http://www.bc4x4.com/tech/2009/jeep-steering/ If it veers to one side or the other when it feels like it, you probally have loose or worn out parts. Get a helper and lay under the truck and have the helper turn the steering back and forth (with truck running for PS) while you place your hand and eyeball on each joint and look/feel for any sloppy joints, etc. Link to comment Share on other sites More sharing options...
87Chief Posted October 16, 2010 Author Share Posted October 16, 2010 It is stock, it was sitting for awhile, so I might just do a maintenance check on it. Might bring it by work and see what they have to say.. It also has a huge oil leak under the engine bay... I know it would help out a lot with pics, but the MJ is sitting in my Grandparents yard in Alabama.. I hope the oil leak is just a bad head gasket. Link to comment Share on other sites More sharing options...
MjPioneer Posted October 16, 2010 Share Posted October 16, 2010 "just a bad head gasket" :eek: I'd check the rear main for the oil leak Link to comment Share on other sites More sharing options...
87Chief Posted October 16, 2010 Author Share Posted October 16, 2010 What would that consist of?? Like what would I take off and such? And how much Link to comment Share on other sites More sharing options...
87Chief Posted October 17, 2010 Author Share Posted October 17, 2010 Should I take it somewhere and let them check it out and see what they have to say and then just buy all the parts and do it myself? :) Link to comment Share on other sites More sharing options...
