ComancheKid45 Posted October 15, 2010 Share Posted October 15, 2010 Alrighty well i just purchased my 4th MJ tonight (10/14) and it is my 1st vehicle with a manual transmission. Ive been around here long enough to know the AX15 is preferred over the BA10 but always thought it was phased into the MJ in 1991 with the HO 4.0 engine. From some scanning and searching I now think my 1990 could have a AX15 installed. If so I'm more excited than i was just purchasing this truck. Its build date is 11/89 so its and early 90s model. Thanks for any info! :cheers: Link to comment Share on other sites More sharing options...
Automan2164 Posted October 15, 2010 Share Posted October 15, 2010 Mid '89 was the change. If its a '90, it should be unless someone swapped a BA10/5 in. Rob L. Link to comment Share on other sites More sharing options...
1974CJ5 Posted October 15, 2010 Share Posted October 15, 2010 http://www.novak-adapt.com/knowledge/ax15.htm http://www.novak-adapt.com/knowledge/ba10_5.htm Just click on these and check under the "identification" section on the pages. Hope this helps. Link to comment Share on other sites More sharing options...
Rymanrph Posted October 15, 2010 Share Posted October 15, 2010 My 90 was built in 89 and it has (had) the AX-15. Link to comment Share on other sites More sharing options...
