Dechion Posted October 6, 2010 Share Posted October 6, 2010 I am sure this is going to turn out to be something simple. Kinda like one of those "if it was a snake it would have bitten you" things, but I'm stumped. :wall: My left turn signal works fine, and so does my emergency flasher for all four corners. When I turn on the lights the green dash light for the right turn signal lights up, not flashing. Whenever I try using the right turn signal the front and back both light up, but are not flashing. :dunno: Is there a seperate flasher for that? Or possibly a bulb that I am not thinking of thats out? (but they work as hazard lights?) I tried looking through the wiring diagrams in the chiltons, they are next to useless for that circuit. :???: Any ideas? Link to comment Share on other sites More sharing options...
mvusse Posted October 6, 2010 Share Posted October 6, 2010 The headlight or tail light is grounding out through the turn signal bulb and instrument indicator. That means you have a bad/missing ground. Most likely in the front wiring harness or plug. Link to comment Share on other sites More sharing options...
Dechion Posted October 6, 2010 Author Share Posted October 6, 2010 A bad ground in the headlight / turn signal area or just somewhere in the harness? (or no way to tell?) I am, unfortunately, new to these trucks. I don't know much about the way they were built yet. I am learning quite a bit as I go though. Also, on the off chance that it might be related, the fog lights don't work at all. Link to comment Share on other sites More sharing options...
JACKED88 Posted October 6, 2010 Share Posted October 6, 2010 See this thread .......... viewtopic.php?f=2&t=25934 No guarantees but that likely to be your problem. Link to comment Share on other sites More sharing options...
