wiring harness question
will the under dash wiring harness from an 86 comanche 2.8 automatic work in an 89 comanche 4.0 5spd???????? both are 2wheel drive
Thats a good question,
Seems a little counterproductive any way you look at it for two reasons
first, your replacement is from an 86 (only year of V6)
Second, one from auto going into a manual.
Seems that there would be many more I-6 parts, harnesses etc to pick from rather one that you might have problems with.
IMO too many variables to take a chance on.
Others might disagree.......
I would have to say no, since the 89 is fuel injected and the 86 isnt. The PCM mounts under the dash so all associated wiring would need to go in there too. You need to find a harness from a lke engined and transed model... 4x4 or 2wd should not matter in this case.
