com_mako Posted October 1, 2010 Share Posted October 1, 2010 -Year, Make, Model. 1986 jeep comanche xls -Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase 4.0L inline 6/AW4/NP242/D30/AMC20/LWB (engine/trans/tcase swap) original V6+ manual transmission -Build date: (its on the driverside door sticker, in the form of month and year) no more sticker -Current Location: Region will do, state, and area of state. Joliette Québec Canada -Status: Is it still on the road, is it in the junkyard? Project awaiting work? still on the road, restore in the next winter-summer -Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift. ext. color: black, int. gray, big ton package, 4.10 traclok, bucket seat, sun roof, 4.0L engine swap with AW4 + selectrac -Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort. me! Link to comment Share on other sites More sharing options...
eaglescout526 Posted May 20, 2019 Share Posted May 20, 2019 Build date: 11/18/85 Link to comment Share on other sites More sharing options...
JMO413 Posted June 28, 2020 Share Posted June 28, 2020 Body Model JP62 *ZZ TRIM STYLE ZZ - PLASTIC BUCKET SEAT -ZZ ADA LIGHT PACKAGE ADL SKID PLATE GROUP AGY Seating Group AHL HEAVY DUTY INSUL PACKAGE AJZ AWJ Visibility Group BAC 75 AMP ALTERNATOR BCQ Battery - 750 Amp Maintenance Free CGW CKA CARPETS - CLASS I SHORT PILE 8 - 12 OZ CLE ACCESSORY FLOOR MAT - FRONT &&&& REAR CUF FULL LENGTH FRONT CONSOLE DDQ Transmission - 5-Speed Manual DMN 4.10 Axle Ratio DSA LIMITED SLIP DIFFERENTIAL EFB ENGINE - 2.8L GM 6CYL GAC ALL WINDOWS - TINTED GLASS GEC Window - Left Side, Front, Sliding GFD SLIDING RR WINDOW GTZ MIRRORS - MANUAL REMOTE HAA AIR CONDITIONING - FRONT HCC HEATER W/UPR LEVEL VENTIL - TYPE II JAY Instrument Cluster w/Tach JFH TACHOMETER - MECH JGB Clock - Digital JHA WINDSHIELD WIPERS - DELUXE JJA CIGAR LIGHTER - FRT COMP K60 BODY SIDE MLDGS - VINYL LBB COURTESY LAMPS (BELOW PANEL) LMA HALOGEN HEADLAMPS LPE EXTERIOR CARGO LIGHT MBJ Bumper - Front, Black MDA FRT LICENSE PLATE ATTACH REQUIRED MFD BRIGHT GRILLE - TYPE I MWB SPORT BAR NAE EMISS CONTROL TESTING &&&& LABEL NFA TANK - 23 GAL FUEL NHM AUTO SPEED CONTROL NMB ENGINE COOLING - STANDARD DUTY RAF RADIO - AM/FM/MTR SBA POWER STEERING SCG LEATHER STRG WHEEL - EURO/SPORT TYPE SUA TILT STEERING COLUMN WJD WHEELS - 15 X 7.0 STYLED STEEL XEA TOW HOOKS Link to comment Share on other sites More sharing options...
