MAP sensor question
Been battling the intermittent high idle at start up (hot or cold engine)for what seems forever. IAC motor, CPS and 02 sensor are new. Ohmed out MAT and CTS sensors today per Chrysler Renix FI System t/s and repair specs.( found link here somewhere, lots of good info)and checked out good. Tested MAP sensor, input volts @ 5, specs 4.5-5. Output volts 3.67, spec says 4.5-5 and replace if not in spec. Started truck and was operating within spec of.05-1.8 volts at idle. My question is if the altitude of 6200 ft. here would make a difference in the output voltage of the Maps. I'm getting alitte tired of throwing parts at this but want it fixed as it's my DD. Any input would be great. BTW, I've checked all the normal stuff; vacuum leaks, grounds,etc. Thanks
Check your TPS sensor. This is the most common cause of high idle at start up. Probably just needs adjusting. I just went through the same thing.
If it was a vacuum leak, it's doubtful to be an intermittent issue. If the MAP is bad, your more likely to have a low/rough idle. These would also cause problems the whole time, not just at start up.
