2360 Posted September 17, 2010 Posted September 17, 2010 A month or so ago I changed my oil with Shell Rotella T 15W40. I've had the Comanche for 20 years, it's got half a million k's on her and I decided to treat the pick up with better oil. What I have noticed so far, 1. The engine is more peppy, get's up to 4000 rpm quicker than usual. 2. I used to be able to see blue smog coming out of the exhaust at 3000-4000 rpm's, now I don't see it. 3. Sensor's indicate the engine is running cooler than usual. 4. I'm not adding oil as often as I used to, plus I don't see the usual oil drips on the ground under the engine. I was planning on changing the head, but I think I'll wait till next summer if it lasts. I've come to the conclusion that Shell Rotella T 15W40 is freakin' awesome stuff.
Lloyd Posted September 17, 2010 Posted September 17, 2010 Sounds like a good upgrade. Maybe I'll give it a try when I can.
carnuck Posted September 19, 2010 Posted September 19, 2010 Same deal with Delo 15W40, Amsoil 15W40 and NAPA 15W50 synthetic. These are more like an industrial engine so they prefer good zinc loaded oils.
