bbe Posted September 13, 2010 Share Posted September 13, 2010 When I turn the key nothing happens, there is a pause, then the starter turn over normally so far. There is a relay mounted with 2 screws between the starter and battery, where and what should I be looking for? bbe Link to comment Share on other sites More sharing options...
WBKrazy Posted September 13, 2010 Share Posted September 13, 2010 sounds like a loose battery cable.. check all the connections at the battery, block and starter and make sure they're all snug... if that fails, the battery could be dying. usually if that relay goes bad it won't start at all. Link to comment Share on other sites More sharing options...
carnuck Posted September 14, 2010 Share Posted September 14, 2010 I agree. The post sizzles for a sec till it makes contact and vrrroom! Link to comment Share on other sites More sharing options...
bbe Posted September 14, 2010 Author Share Posted September 14, 2010 This sounds very possible, this morning it would not start so I put jumper cables to the battery had the pause then it started. thanks, bbe Link to comment Share on other sites More sharing options...
