com_mako Posted September 13, 2010 Posted September 13, 2010 Year, Make, Model. 1990 jeep comanche pioneer Engine / Trans / Transfercase / Front axle / Rear axle / Wheelbase 4.0L inline 6/AW4/NP231/D30/D35/LWB Build date: (its on the driverside door sticker, in the form of month and year) 1/90 Current Location: Region will do, state, and area of state. Joliette Québec Canada Status: Is it still on the road, is it in the junkyard? Project awaiting work? still on the road, but the frame need a restoration, will be done in winter Notes: Anything that makes this comanche different from the rest. Skid plates, plows, lights, bumpers, weird factory options... Would also be a good place to note the exterior color, and the interior color and combination, IE, Bench or buckets, Vinyl or cloth, column shift or floor shift. ext. color: sand gold metalic, int. color: tan cloth, column shift, bench seat, factory winch (rare) up country suspension/skid Current owner: Well, you know. Put down who has it, the yard its in, or anything of that sort. second owner, so me !!
JMO413 Posted May 28, 2019 Posted May 28, 2019 *X1 TRIM STYLE X1 - CLOTH BENCH -YY 122 Zone 22-Canada-Quebec 1AB Canada Dealer Retail 3N8 Drive Away Program Tracking 3PW 5YR/60,000 - Added Care 4EA Sold Vehicle ADA Light Group ADH Heavy Duty Electrical Group ADL Skid Plate Group AHL Heavy Duty Insulation Group APA Monotone Paint ARL 300 Premium Group AWE Night Eagle Package BA1 100 AMP ALTERNATOR BCY 475 AMP BATTERY BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKA Carpets - Floor and Cargo Area CSR Passenger Assist Handles DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERB ENGINE - 4.0L I6 MPI GAS GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEC Front Left Side Sliding Window GFD Rear Sliding Window GNA Rear View Day/Night Mirror GNB Driver Side Illuminated Sun Visor GNC Sun Visors w/Illum Vanity Mirrors GRZ Left Remote Mirror GSZ Right Remote Control Mirror GTZ Manual Remote Mirrors HCD Do Not Use - See HCA HGD Deluxe Insulation Group JAZ DO NOT USE - See JP, KA classes JDB 180 KPH Primary Speedometer JHA Var Intermittent Windshield Wipers JJA Cigar Lighter K2X STRIPE/BADGE/MOLDING/COLOR K3T STRIPE/BADGE/MOLDING/COLOR KKG LAJ Headlamps On Warning Chimes LBB Courtesy Lamps LBC Glove Box Lamp LBD Ash Tray Lamp LBE Door Armrest Storage Lamp LCJ DOME/READING LAMP B-PILLAR LDH U/Hood, Removable/Rechargeable Lamp LHD Headlamp Off Time Delay LMA Halogen Headlamps LMK Daytime Running Headlamps, High Beam MB1 Black Front Bumper MBJ Black Powder Coated Front Bumper MDA Front License Plate Bracket MFG Body Color Headlamp Bezels MHA Black Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMK Lower Grille Surround-Painted Silver NAA Federal Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon NHB Auxiliary Transmission Oil Cooler NHK Engine Block Heater NHM Speed Control NMC Heavy Duty Engine Cooling PY3 Classic Yellow Clear Coat QY3 Classic Yellow Clear Coat RAA All Radio Equipped Vehicles RAF AM/FM Cassette Radio RCD 4 Speakers SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFD Front Extra HD Shock Absorbers SGD Rear Extra HD Shock Absorbers SUA Tilt Steering Column TAA All Tires TBB Full Size Spare Tire TBM Tire Carrier Winch TRN P225/75R15 OWL Wrangler AT Tires WJD 15X7.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box XEA Tow Hooks YAC Build To Canada Mkt. Specifications YBA 30.2 Liters Of Diesel YGA Without Billable Fuel Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z86 Right Front Spring Group XV Body Model JL62 Build Date 1/21/90
jdog Posted February 6, 2021 Posted February 6, 2021 Selling Dealer: GARAGE PARENT ENR. Drummondville, QC (CAN)
